cant find vacuum leak
scguru92
I did the brake cleaner test over all the places I thought of. What are the usual culprits for a vacuum leak on a 4.0?
Thanks
try the rear of the engine at the intake gasket. they are known to leak in that area.
One by one, disconnect and plug different vacuum circuits, See if you find and isolate a bad line or vacuum motor.
Also having a scanner w/ live data really helps here, you can watch the Short Term Fuel Trim, and O2 sensors. Scanners work alot better than listening to your computer controlled idle.
only dam draw back to 4.0's is this dam infamous vaccum leak
