Can someone tell me My gear ratio?
learningcircles
I'm replacing a broken front axle, and the salvage yard needs my gear ratio to match the axle. I can't find anything here that tells me what it is, but here is my rear differential's tag. I assume the front diff would match?
edit: uploaded wrong picture
thats not your rear diff, thats your transfer case
What does your door sticker say?
ok I'm looking at the correct tag, and it is part number 610483, I can't see enough of the tag to see the gear ratio. Any guesses?
check the passenger side beam for the BOM sticker, it will say the gear ratio, also the door sticker may say it.
judging by your screen name, you're into stunting? how far away are you from completing a circle if so?
here is the door tag, does that help?
