- May 1, 2018
- Seattle, WA
- 4.0 V6
- Manual
I started getting a 214 CEL code so am looking into swaping my cam position sensor. It looks like I can buy just the sensor, but it seems to have a different plug for the wiring harness compared to mine. I found this tech article here which says you can just swap just the sensor, instead of replacing the whole synchronize, but even its images show the difference in the parts. https://www.therangerstation.com/tech/ford-4-0l-camshaft-synchronizer/ Scroll to the bottom for new part and then scroll back up to see the different plug.
Mine has a plug that makes a 90 from the synchronizer so it is vertical with two tabs on the sides to hold the plug on. All the photos I can find of the replacement show its plug as horizontal with a single tab on top. I can not find anything to show how this actually works but the tech article says it does somehow and, the new sensor that looks different is listed for my 94 b4000. What am I missing here!?!?! I am serriously scratching my head and even looking at that tech write up I have no idea how it would work with a different wire connector then what is on the harness. Thanks.
