Cams..Learn me about them
he said it was pining before the mod, so whos to say its causing any problems (as dave said, several members both here and over at RPS have done this with good results and no leaning issues).
the very small error this mod may cause the MAFS to read can easily be picked up and corrected by the O2's. after all, thats their job.
You are correct Bob but, keep in mind two things. 1. That modifying the MAF sensor, if done correctly, needs to be accompanied by a change to larger injectors. 2., and most important, the computer has adaptive limts and learns what injector pulse rate goes with what reported MAF sensor voltage. The computer will adapt very quickly to the new components and no lean out under WOT should occur.
