offroadranger
- Nov 9, 2007
- Age
- 97
- Automatic
Hope this helps!
ford injectors
19lb - orange
24lb - light blue
30lb - red
36lb - dark blue
42lb - lime green
immensly! thanks!
Hope this helps!
ford injectors
19lb - orange
24lb - light blue
30lb - red
36lb - dark blue
42lb - lime green
The idea behind drilling out the sampling tube is to change the ratio of air that passes through the tube vs the meter to better match your new injectors. Basically your attempting to fool the meter into thinking that less air is passing through the meter so that it reduces the injector pulse that's going to your larger injectors. It sounds complicated but it's not really.
As for the actual modifying of the MAF housing, there are two different types. sounds like you have the older one.
Man, thats never happened to me, then again I didnt modify my MAF. All that I can think of is to reset the EEC (disconnect the battery for 10 mins) and then drive it around so the computer can readjust.![]()
Hmm. OK, but if your fooling it to think theres LESS air coming in.....wouldnt the computer then give LESS fuel? So does that mean the 19lb are too much and were going for somewhere inbetween 14 and 19? I have a decent amount of modifications. Gonna be good? Thanks again
