I have been doing hours and hours of researching through single swing threads. And it seems like that is the setup to go with.
The problem is I heard it doesn't go well with lift brackets...i guess because the angle the steering rods will have to go from the pitman arm to the drivers side beam will be more extreme. And so will the other side.
I have also been considering using an idler arm...and imitate superlifts design. But of course using chevy 1-ton tie rod ends. I am considering both.
The problem with the idler arm is getting it the same height as the pitman arm. (It would look like crap if it was uneven.
seriously, look thru disciplerocks build...
http://therangerstation.com/forums/showthread.php?t=92406
i'd start at the beginning.. just b/c its a good read, but idk what page the steering starts on.
I didn't mean a 1/4" difference...more like 4" difference! I honestly can't tell with your setup.
I can't tell but what is the idler arm mounted too? I think going custom and copying your design (superlifts) would be the best choice.
It doesn't look like there is much to it. But what worries me is finding the right sleeve/bushing for the idler arm. I don't want to put something squishy in there and the idler arm to move all over the place. Its kinda pointless for me to buy a super runner to just tear it apart and modify everything. Might as well start from scratch.
Ok so here's a question.
1) In order to have the idler arm closer to the two steering arms I would need a drop pitman arm?
2) To avoid bump steer the steering arms need to be level...even in this design right?
Thanks for taking the time to explain that to me.
This will be my dd. So the superlift method is what I need.
