- May 29, 2008
- Manual
srry i didnt no if i should put this under non rbv or the audio and video so here it is. my question is thati have a goal to have the best system on flats on a low budget. as of now i have a sony cdx m30 head unit with the sub pre amp outputs and i have it amplified by one of these http://www.allaudioexpo.com/nav/details.asp?itemid=2606&catid=103 now it sounds good on two jL 7.5s and two cheapo 6.5s but id like it to be louder and hit harder. my solution was to add one of these http://www.allaudioexpo.com/i/pyle_plmrw8_8_400_watt_high_power_m.html or maybe a 10" version of this sub but either way i need more power so should i run one of these http://www.allaudioexpo.com/i/pyle_plmra200_2_channel_400w_waterproof.html off of the sub preamp outputs to the sub and leave everything else the same (except the 6.5s which im changing regardless most likely to thesehttp://www.sonicelectronix.com/item_13976_Sony+XS-MP1620B+-Black-.html ) or should i buy a 960 watt peak power 400w rms @ 4ohms power acoustic 4 ch car amp for 40$ and use my 400w 4 ch for the sub. and if i did the later of the two would the sony 6.5s hold up to that much power
so im going to take a look at the guys amp tomoro and if all is well i gues ill use the 960w to power the 4 speakers and the 400w bridged to power the sub(s).
