Bucket seats in my 83 single cab inquiry.
832.3ranger
Forum Member
Greene New York
I am wondering about a simple way to mount bucket seats in my truck that looked clean and not hacked together like some of the ones I see online with angle iron. I plan on v8 swapping and I want a center console for the shifter and 2 cup holders but I don’t like the bench seat options for the both of those things. I want a full center console I’m going to build custom with sheet metal and bolt to the transmission tunnel and floor that fits the look I want of race car but classic and custom. I’m not going to use explorer of newer ranger console they look to modern for the truck.
Bucket and 60/40 seat rails are the same. 83-88 Should be the same floor mounts. 89-92 possibly.
Then you can use seats from up to 97 Ranger or 01 Explorer. Might be easier to find style appropriate buckets from an 80's Mustang that has been swapped to "racing seats".
Like SenorNoob said, seat tracks from an 83-88 Regular cab Ranger with buckets or 60/40 split bench. Attach your chosen seats to those. For a factory seat, that is probably the best option. Alternatively some companies may offer a racing seat base that fits the truck, then attach universal sliders and seats to those.
For period correctness you could find buckets from 83-88 Ranger or BII. If you want something a little more supportive and sporty, look to the fox (or earlier) Mustangs. The problem with many newer seats is that they are high back and/or thick, that pushes them forward and there isn't a lot of room in a Ranger to begin with. Many of those 80s Ford bucket seats used the same mounting pattern on the base, so the tracks will bolt on. Those that don't can usually be done with a simple bracket between the seat base and Ranger tracks.
Another good option if you can find them might be some 70s-80s-90s FloFit or Recaro seats. They may require more work to adapt, but should fit well thanks to their thin seat back and base.
The FloFits were used by Saleen in the 80s foxbodys and they also used them in a handful of first gen regular cab Rangers, but I think they were discontinued in the late 80s. Also a lost sold in aftermarket. Not easy to find, but are out there. I scored a used set locally earlier this year.
Recaro LSX (IIRC) were used used in the pace car Mustangs, a lot of other cars, and a lot sold in aftermarket. Practically the same dimensions as FloFit and arguably the better of the two. These are fairly easy to find in all sorts of conditions and pricing to match.
My 83 did not have the inner 2 holes for bucket seat i had weld in a reinforcement plate under each to have some thing strong enough for the seat if you find a 60/40 bench first gen you could just modify the 60 part into a bucket seat as many other people have done on here
older thread i see... but cheers... go to posts ... 61 84 86 89 121 cheers
