- Dec 24, 2007
- Automatic
hey all my project is a 84 bronco II with a 2.8l c5 auto.it use to be a stick but is now and auto. it has a 3" body lift and the rest is stock. my problems started with the tfi ignition. so i got the necessary new parts to do the dura spark conversion. i was having difficulty with the wiring so i sent the beast to my local 4x4 shop thinking it would be the quickest route to get it done. i told them to rip out the old tfi ignition and install the duraspark wiring since i already installed everything else. i get the truck back and it started great and seemed fine till a little while later i popped the hood and saw what they did. the old tfi ignition is still in the engine bay and so is the dura spark ignition. upon closer inspection they seemed to have taken the wiring for the dura spark ignition and spliced it into the tfi ignition for some strange reason. i asked them about this and they said they tried everything according to the diagrams and info from this sites tech section and nothing would get the truck to start is why they did it this way. i am so pissed and will never go back there. now the second issue is they told me that the neutral safety switch was cracked so i told them to just replace it so they did. now i go to and try and hook up the kick down rod and now it won't line up. i am now trying to fab something together or try what a buddy suggested is to use a kick down cable instead of the factory rod. any advice?????
