- Jul 25, 2011
- 88, 89 bII
BII front end compatibility
89-90 Bronco II front clip is a direct bolt on to 88 and older BIIs, with the following notes: You must use the radiator core support from the 89-90 in the 88 and older models. You must also use the headlight wiring harness from the 89-90 BII. I strongly encourage one to also take the windshield cowl from the 89-90 because it is better designed, and works with the improved wiper arm design of the 89-90 BII, because you are able to adjust the arms to come to rest @ the off position in a much lower place, eliminating the "to high" position of the 88 and older BII that is an obstruction and distracting. I have done this twice, and I agree with you, for many reasons, the 89-90 front end looks way better, is more aerodynamic, and wiper performance is upgraded as well. You will need a spot weld cutter drill bit for the radiator core support spot welds, and in the front bottom corners there is a long bolt with bushings that will need the be replaced. Good luck, BBFL
