Broken Clutch Pedal Linkage
Alexkoch
5+ Year Member
SF Bay Area
Hi everyone,
After removing my slave cyl/trans to fix a roasted pilot bearing, I mistakenly depressed the clutch pedal for some reason and buckled the "linkage" that I believe connects to the master cylinder.
Does anyone know if I have to replace the whole master? Is the "linkage" effectively the con rod to the piston inside the master or can I buy the linkage separately? Such a dumb mistake.
Thanks,
Alex
You can sometimes find push rod as separate part, but Master does come with new push rod
