brake ?
7111127
Coweta Oklahoma
alright i am doing a swap from a 84 bronco ii changing all the stuff 2 a 95 ford explorer setup
i took the wiring harness and everything out of the bronco and put in the explorer stuff
there is a thing that the brake lines to went to that divides them on the bronco ii and had a wire plugged in to it on the explorer there aint one it had abs setup and i not takin the abs but am taking the brake master n shit wut do i gotta do 2 make it work can i just hook the lines in 2 off the master and not worry about the thing that divides them wires that was going 2 it?
If you don't the ABS (and possibly cruise control I'd just leave the B2's brake system as intact as possible in it's current form.
I left the brake system in the bronco and changed the power brake unit with the donor.This made stronger brakes but the lines still fit as gen 1 has a 7/8" M/C and gen 2 has 1" and gen 1 has a single diaphragm and the gen 2 has a double I believe.
