Brake light problems
booblinker
Richmond twp, mi
I have a 93 ranger, third brake light works, but the other two don't. I changed the bulbs, and still don't work. Need to know where to go from here.
get a volt meter or test light, and check the harness, there should be a plug right up under the bumper just left of center when looking at the back of the truck. that plug should be the entire harness for the back of the truck. you'll probably need someone to tap the brakes for ya or set something heavy on the pedal keep the signal there while you check. with no other lights on and the brake pedal pressed you should have one "hot" hopefully this helps some
