2.5L ('98-'01) Brake issues
Jax
Got my deceased fils 99 b2500 2.5 auto. Brake pedal didn't return after pressing and truck would hesitate until I toed the pedal up.
Completely redid the front/rear brakes, replaced master(bench bled) and booster. New lines and reverse bled system.
No change. Does the same thing. Used vacuum fogger and fixed several small leaks figuring maybe bleeding vacuum. No change.
At wits end and am asking if anyone has/had same issue or any ideas?
Not on the level as our experts but does it have 4 wheel abs or just rear abs? If only rear, maybe the proportioning valve is an issue
Again, not an expert.
Thanks for replying. 2wd. I didn't think to check that but am on it. Thanks!
