Brake booster delete
Hey Jolene, thanks for the info and pics and stuff. BTW nice setup you created there!! I'm using my manual toploader so I'm probably leaning toward that Wilwood tandem setup, 3 m/c's ( front brake calipers, rear brake drums, and hydraulic clutch). I'm thinkin I need 3 individuals. The fronts are 4 piston Aerospace calipers (non vented rotors), rear drums are Level 2 10" (13/16"cyl. bore), and the clutch. Kinda takes all the guess work out of the mix!
I really like your strut mounts and have a couple of Q's regarding them. I won't be off road so is it advisable to mechanically connect the 2 towers to each other for rigidity and what caster degree and camber degree did you choose? Thanks,Jack
i mounted the shocks so that they are perpendicular to the I-beam center line and radius arm center line when the suspension is fully compressed.
if your shock towers are as high as your master cylinder i would definitely advise connecting the two with a cross member regardless of application. thats alot of twisting force on the frame with a shock way up there.
knuckle caster is about 10* at ride height and about -1 ish camber at ride height
Agreed. I didn't realize you were on a TIB suspension. That explains the camber. I installed the fox body K member which gives me 15-16* camber and I set the caster at 10*
