Hi guys, 1990 2.9L 6 cyl here. I was performing a routine brake bleed and flush and an issue came up with my back left wheel. That wheel simply will not bleed - I completely removed the bleed bolt and cleaned it (it’s not the issue). Even after removing the bleed bolt and vigorously pumping the brakes, I couldn’t get brake fluid to show up. Any advice on how to continue root causing the issue / possible causes?
