body lift
blue_eyed_devil
Are the body mount bushings the same on a bronco 2 and a ranger? also are body lift spacers and bolts the same? i have both brand new for an 85 bronco 2 and id like to use them on my 88 ranger i only wanna lift the cab and front end because the bed is going to be removed.
go to the LMC truck parts web site and look up the bushings. it will tell you if they are the same. they are a great reference for older rigs. gut feeling says yes, they should be the same, but check for sure. good luck!
No, they are not the same, at least as far as the bushings are concerned. Although, if you're willing to throw away half the bushings, you might be able to get away with using them. (Rangers require 6 bushings, Bronco IIs require 10). I'm pretty sure some of the bushings are different sizes between Rangers and Bronco IIs.
Spacers are the same length, but again, you'll have an excess of parts.
thanks for the help i looked at the lmc catalog and the front 6 bushings and bolts are the same for both trucks. i already have both kits for the bronco so i may have extra parts but still cheaper than buying another lift and bushings for the ranger
