Body lift advice
For the spacers, jack up the truck, take the wheel off and let the suspension droop all the way. Then grab a 1-1/8 wrench or socket and take out the nut that holds the lower coil retainer. Pull out the coil, put the spacer in, put the coil on top and reassemble everything.
You may need your pal to step the axle to get another inch or 2 of droop if the coil still doesnt want to come out. Its pretty simple.
You can also stack some large washers under the coil and it would be far cheaper. If you ad spacers though, you will need an alignment.
