Blown Motor Mounts?
GO GET MOROSO SOLID MOTOR MOUNTS
you will literally never replace them again, and they are cheaper than factory ones!! They DO NOT wear in any way shape or form, nor do they rust
Do not ever put a solid trans mount on, unless you have solid motor mounts though, otherwise you will be replacing your bellhousing...
Apparently they don't make them for '95 rangers. :/
Do a google search, there's a few companies that make solid mounts for your truck
So far I've found that Ruff Stuff makes them, only for the 4.0 though.
Auto Fab makes them but they're around $250 for a set - a bit out of my price range.
Any others or should I go with factory, or the ones from Advance?
make a set out of the ones on your truck already...
