I think it's stalling because the idle is so rough. When I go from drive to reverse it idles down so low that it dies. He did a smoke test and everything is sealed up. He double checked the plug gapping and they were all right on the money. I don't know what else it could be other than the timing being off.
I think he said he got 12 on the vacuum test. The engine does smooth out while driving. If I'm cruising on the highway it runs smooth. It's only rough when idling.
I did a vacuum test with my gauge (which I know is acurate) and the engine at 1,000 RPM's and I got 16.5-17.0! I retested with the engine at idle and got 12.0-12.5. It's got to be the timing!
Turns out the timing was off. He said it was only off by a fraction of a degree but it was enough to cause the intake valve to hang open a little too long. She runs perfect now!
