Blew a PS Pressure hose
stimmie78
Uinta Basin, UT
Had to rearrange where our vehicles were parked in the driveway tonight so I was playing musical cars. I moved the Olds first and then had to move the Bronco. Since the wife parked the Buick behind things I had to back up around it. When I got clear of the carport I turned the wheel full lock to the right. Heard a pop and didn't have any power steering anymore. I moved the Bronco to its new parking spot and found the pressure hose had popped out of the fitting off the pump. Is the o-ring just bad or do I need to replace the entire hose?
There's a little metal clip inside the fitting that holds it together. I had one go on mine a few years ago. I made a new clip out of a piece of thin sheet metal.
