- Jul 4, 2008
- Automatic
I just put on a new AGR power steering pump on my Ranger. I have been trying to bleed the system by going by the specs AGR says. I replaced both the high pressure and low pressure lines and checked all the fittings countless times for leaks and I still get bubbles in the resi when I bleed it. I even loaded the fittings with thick grease to see if they were sucking air in somehow. Truck is off and its up on jack stands when I am bleeding it turning it lock to lock. Is this something that usually just takes for ever to bleed? Any other pointers would be greatly appreciated.
