Biggest Ranger In Jersey???
yeah if i get a flat I have the brand new tires so ill just call the tire company i use were going to have a small rolling shop to back this thing and a few of my buddies trucks up because we know there will be issues
still looking into a ladder or winch operated step bar not sure what direction to go Ill post some pics of the rear being clearanced its pretty neat to see a 200+lb housing spinning at 220 rpm on a lathe!
No more drive thru line at McDonalds, only the semi-truck lane for you!!!!! :D:D:icon_thumby:
This is going to turn some heads..............................:headbang:
Still stoked by this project, keeping tabs on this thread. How bout one of those emergency scissor ladders? Mount it under the cab and pull it to get in and push it down to get out.
I vote rope ladder! Just keep it neatly rolled up in the extended cab, then toss it down when you need it. But you might want to invest in some "California style" door releases to pop open the doors through a key fob.
My idea to get in... and it's cheap
Build rock sliders, although useless for rocks... Climb the left rear tire and shimmy to the door. Done:icon_thumby:
Go to a hunting store like bass pro if you have them up there or order them from cabelas. They are called climbing sticks. It has little steps on it about a foot apart all mounted on a central rod. Make something under the rocker panel you could hang the top of it on and then once you get in the truck pull it up and put in the back seat. Some of them collapse and some are rigid. Once you get out the truck and unhook the stick just hang it up under the truck some how. Just google "climbing sticks"
Ok, i figured out how you could get in.
Tie a strap around your rear axle yoke that runs through a winch fairlead built into some sliders under your rockers, tie the end that comes through the fairlead around a 2x4 to stand on. Then build a remote controll for the truck, and then as you idle thanks to the remote control the strap will wrap around your yoke and pull you up.
OOOOH!
Maybe throw in some lambo doors, but then have a folding rockwall that falls out and you could scale the truck. ON BALAY!
If you've got a receiver hitch you coul weld some square together to make a ladder in the rear, maybe tie it into some tiny stock mud flapps with the naked girl on them. Yeah. Climb up it and creap your way over to the cab on some sliders.
Or maybe hire a crew of circus midgets to stack on top of eachother and you climb them up.
OOOOH! Or get a big circus russian strong man and have him just throw you in dukes of hazzard style.
It's noon somewhere! :beer:
This is great my step father owns a bow hunting/pro shop in PA I cant believe neither of us thought of this Im working on it this week thanks a lot man!!!! :yahoo:
