- Apr 8, 2025
- Florida
- Manual
did some work on the heads today while i wait for the coilovers to come in. i will be using the stock 7.5l EFI heads, and exhaust manifolds. They where working fine when i pilled the engine from my F350 so im just going to do a deep clean, replace the valve seals, and lapp the valve seats.
Here is my valve spring tool i made today. the scrap pile saves the day, again.
i dont know how many miles where on the engine, but there is some carbon build up on the intake valves.
I found a "Repair" that the previous owner did. they stripped out one of the exhaust manifold bolts and decided to weld a stud to the head. i found this out after i tried to remove the stud and part of the head came off with it. i guess i will only use 7 out of the 8 manifold bolts.
After 30 years of use 2 of the intake manifold bolts were also stuck so i had to add some heat to remove them.
