bench bleeding brake master cylinder
upnorthdad
Hi,
How do you bench bleed a new master cylinder.... the directions that came with it are bad.... I understand why you do but just can't figure it out.... I have 2 hoses connected to each other from the new master cylinder... Help please...
Thanks dave
screw the hoses into the ports and run the other end of each hose into the resovoir. then push the piston in slowly
