Bed adjustment
Chuckweasel
Have 2001 Ranger with slight misaligned bed. What is involved in turning bed on frame? Truck has bed liner that covers entire inside of bed.
While you can shim bed and body bolts, I'd be quite concerned that "misalignment" is collision damage and the frame is tweaked.
Tail beds are actually pretty easy. You'll have to pull your bed liner out then loosen or remove the bolts in bed, should be six large ones and the bed can be shifted. Just be careful of the full filler neck and tail light harness if you have to move the bed a whole lot or remove it.
