beating a dead horse
tjdeerslayer37
Dearborn heights mi
ok dont kill me guys, ive searched and cant find anything.... is anyone using shorty headers? im trying to not spend over 120 on headers and i need something that i dont have to modify too much. i have a 91 2wd im putting a t5 in it with the 5.0.
if not shorty headers, what else will work that is cheap? id really like headers over the exploder manifolds...
maybe ill just have to bite the bullet and get the tri-y ones. i cant find a set for less than 150 plus shipping.
btw, will the flywheel from my 2.3 manual work for my 302 with the t5 or do i need to get a different one?
The tri-Y's fit perfect, as you are 2wd.
And you will want a flywheel for the 302. You'll need to change your transmission, too. If you currently have a T5, and plan to keep the 4cyl T5, you will still need a v8 Bellhousing.
Tri-y's will work with a 302 and T-5. You will need the correct flywheel for your motor (157 tooth and whichever imbalance factor the motor requires.)
