Bay state rangers?
Is it that important to have the tow hooks? I don't have any..if it is a big deal I will not go. I don't want to get stuck so far from home.
David
Well, without tow hooks, your gonna be crawling under the truck to hook up if you get stuck. I'm bringing a chain, strap, and highlift. Winches anybody?
ok yeah lets meet at 10 then. i dont have a winch but i will have a tow strap and shovel.
tow hooks are not mandatory.. but like noted. you will be crawling under if need be..lol and NO BOOZE AT ALL>>>>i`m mite be jinxing us but a winch should not be needed
I have a winch.
Tow hooks are recommended. However we can get the job done without them. I have a good assortment of recovery gear but everyone should bring what they have.
metal macguyver i posted it on rangerforums also.. i have a few friends over there.. hope no one minds...
if it's the truck in your signature than you should be able to make it. I did it before I had 4wd in my truck and you just have to get pulled every now and then. Your truck has a bit more lift and larger tires then when I was 2wd so you may have an easier time at it. It shouldn't be a problem especially if you have front and rear tow points.
I hope you guys had a good time and someone took some pictures. Maybe next time.
