Battery died/Charged it now No Power to anything!
hunterh2
Hey guys,
I had my bII running great and decided the gf should learn driving standard. We were driving and after she stalled it a couple times the battery died so the engine wouldnt turn over. I took the battery out and recharged it and even took it to get it checked out and its a good battery still.Only like 3 months old. The bII gets no power to it at all. Not even headlights. If you can help me out I'd appreciate it. Thanks.
Check all your wires. They can get corroded real bad inside the wire cover and will not let it get any conection, just did it to mine .
Yeah, check the connections at the battery, make sure they are clean etc.
Get a volt meter and go from the battery onward and look for where you lose power.
My 89 BII has a ground near the battery that if I bump it and make it loose then the truck wont get power and not start. Clean your terminal ends and get the volt meter out . Could be anything.
not sure if the b2s have one but i thought most cars and trucks have them see if it has a fuse link
