- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
well it says crank the engine and that's the whole problem I can't
all I can potentially do it test if the voltage is the same as at the battery while it's sitting there
at this point I'm about ready to just replace starter AND wiring harness and be done with it. IF I can find wiring harness, thought I saw it the other day now can't find it. isn't 23 years enough to ask of one? You know all the coverings are brittle as sh*t and if I'm doing the job and have it up I might as well just get known good stuff in there, right? It looks like there are not a lot of connections for the harness, it goes to fuse box in bay, and has a connector running to, probably ignition switch, and it goes to the starter. I think that's it.
