Dezert Runner
Right now Im only getting 13.5 mpg out of my Ranger.
SOHC4.0 4x4 5-speed. 305/70/16s. Im not 100% sure what gears I have but I can do 80 on the fwy at 3k-3200 rpm.
Before it was idling a little rough and when the A/C kicked on at idle the truck would nearly die. I replaced the fuel filter and used some fuel system cleaner but my mpgs got just slightly better.
Suggestions?
On the hard start...
My truck sometimes will crank for a while and not want to start if it has been sitting for, lets say, more than an hour or two. When it does start it sometimes stumbles for a couple seconds then idles ok.
If I cycle the key 2 or 3 times it will fire right away usually.
What should I be looking for? Fuel pressure? dirty injectors (ran that system cleaner) starter?
Brand new Red Top, new fuel filter.
Suggestions?
