b2 drive shaft
509lifted
Firefighter
chelan washington
idk exactly what drive shaft and i need a new one cause mine just busted today i have a 84 b2 4x4 with manual 4 speed tranny would u guys know which one i have cause it broke right at the ujoint i beleive but im not sure.
yes i beleive it does and then it had a single one at the axle
Post measurements. Someone might have one laying around.
that would make it a double cardan shaft which is the better of the bronco CV type.
country idk how to measure it do i just go from end to end what cause right now im still figuring out how to take it off cause there is so much oil and grease on it. i guess my mom got ahold of a guy that can fix it if not it will cost 400 for a new one from him or 300 for one online.
Get a stick and mark it at the tcase and rear axle. Then measure it. Post pics if you can
here are some pics
b2 drive shaft
b2 drive shaft
b2 drive shaft
b2 drive shaft
b2 drive shaft
Hey, you locked up a U-joint.
Make sure you get it re-tubed or you will keep breaking yokes and joints.
so does that mean i should just buy a new one cause i really need to get get this fixed so i can get back out to finding a job oh and i cant get the part off the differential i have the right socket it just wont budge even with a cheater bar
The drive shaft bolts are thread-locked in and probably corroded. When I put a clutch in mine last year removal of the drive shaft required a butane torch, 2 wrenches, a leg, and a good bit of pain and screaming.
I'd heat the area around the bolt, hook on with a wrench and the cheater wrench and push with my leg while my wife held the brakes.
And yes, there is a 100% chance of a bend in the tube, even just a little bit of one can cause massive problems with repeated breakage.
finally got it off the differential but bow im waiting on a socket to get it off the trans since it is a different size bolt i would think they would be the same size
400 for him to make a new shaft ouch i just had a explorer front shaft shortened for my b2 and it cost me 75 and it came with new ujoints
