Axle shims
scrapper
central IL
IL - USA
Drive
I have searched on here but must be looking in the wrong place. I lifted the rear end up 3" but am sure it would need angled shims? I could be wrong no idea. I'm not sure how much shim for how much lift. I may be posting in the wrong place? Thanks for any help. I am thinking it would be some great info for the tech library or a sticky.
3 inches isn't that much I don't believe it affect the angle that bad what you need to do is find out the degrees between it to your rear end in your driveshaft shouldn't be more then 3 degrees difference. Just Google it and you should readily find the information.
