AAAAAAAAAAND guess who gets to drive it in the done deal video. Yep... tha brat.
Uggggg gingers make the world go round.... ish.
is it your toy or hers? feisty as she may be, you're the boss!
AAAAAAAAAAND guess who gets to drive it in the done deal video. Yep... tha brat.![]()
I am. I expect you will look out for her also is that a fact?!
Yes they are. You for the most part drive it like a regular truck but there are some odd/ backwards things that if you dont know your hosed. Over rotation being one and foreward undercutting another... dry steer even with modded pump ect forget it you will mess things up. I have alot of time running them so i know alot of tricks. This rig should do about 45 mph on groomed stuff, sure you can go faster but do you really want to.
Can you explain what some of those terms (dry steer, forward undercutting, over rotation) mean?![]()
They have a torsion rubber bushing shaft that allows so much rotation but forcing it beyond will screw em up. I will take pics of that part for you.
You don't have to try to flip the tracks off just for our sake.
I would suppose the camber changes of a wheeled suspension plays havoc with trying to back up too? (when the tire leans with the bottom kicked against the turn for more traction)
I have heard tracked tractors ride really rough compared to a comparable wheeled one too... which makes sense because aside from the tires all you have for a suspension is under the seat.![]()
For the most part camber is not an issue if you use these as intended for snow and mud, its senceless to run $35,000+ tracks on a hard surface.
