Are steering stabilizers worth the money???
Wow alot of words were laid down while i was gone.......
Anyways I dont have a lift kit, just stock ('96 mazda b4000, 4x4). Would i gain any benefit from putting one on my truck??? Front end is pretty perfectly aligned to my understanding........
just give it a once over, check ur TRE's, ur ball joints all that fun stuff, if they all check out good then u could run one to just smooth the ride out a bit.
Check tire balance too. Weights can sometimes be thrown and sometimes tires change balance as they wear. I had a nasty vibration with the unbalanced 33" bias-ply tires on my choptop. Got some balancing media and put 1/2 of the recommended amount in the right front tire (only stopped there cuz it started to rain on me). Since I needed the truck that night, I aired back up and threw the tire on the truck. Amazed me that it solved the vibration issue, which had also contributed somewhat to bump steer, so the end result was that my truck became much more driveable.
