I vacuumed my system down then added the Propane to it.  Probably around 14 ounces if I had to guess.  I stand behind the statement that the leak if any that would be in the system it would be quickly apparent from the rotten egg smell.  In the event of a wreck I don't see much more risk then from the gas in the engine bay, or the transmission fluid that is hot and in the cooler...
R290 (propane) is a common refrigerant.
Used in a lot of applications.  It is my understanding that it has very similar properties to R22.  And is a common substitute for R12.  Auto ignition temperature is 840 or so degrees Fahrenheit. The flammability flare limits are only from about 2 % to 10%.
Other information as I have read in other places.
- It works better than R12 so a full charge (no bubbles in the sight glass) is too much.
- When ignited, it burns, leaving some heat and CO2 behind. R12, when it burns or is heated in the presence of a fire, results in
phosgene gas being released. Phosgene gas is one of the more interesting Nerve Gasses used during WWI to kill troops. This is not a plus.
- R290 is fully compatible with R12 lubricants.
Also if there were a wreck there won't be any "nerve agents" from the heating of R12...
The recommended fire fighting instructions from the MSDS for R12 is that
"Firefighters should wear self-contained, NIOSH-approved breathing apparatus for protection against possible toxic decomposition products. Proper eye and skin protection should be provided. Use water spray to keep fire-exposed containers cool."
