Sasquatch_Ryda
TRS Staff - Retired
Forum Staff - Retired
Ford Technician
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
- Aug 8, 2007
- Age
- 38
- Terrace, BC, Canada
- 4.0 V6
- Automatic
- Tire Size
- 40s
How do you keep your plants alive in the gravel?
Mine always started off great then slowly died off, and a buddy said it was because of the gravel; said I should use dirt or sand instead.
Plants will grow just fine in gravel...I am using CO2 injection and plant iron enriched fertilizer on a regular basis. Also I try not too clean around the plants too often with the gravel vacuum as they will use the fish waste as fertilizer. I've been keeping live plants that way for over 3 years now without problems.
dude... you put discus into a brand new tank?
The tank is new, not everything else. I switched them over from a 46 gallon bow front. The gravel is already cycled as it was in the other tank, I put about 35 gallons of the water from the other tank into the new one, and my new filter on the 80 gallon uses the same filter media as the filter I had on the 46 gallon so I'm running that in the new filter. Everything is already cycled and ready to go. I test the water quality every couple of days because I like to keep my iron at the right level for my plants and I like to keep the PH down for the discus. Discus aren't a new thing for me.
