- Jun 1, 2001
- Age
- 64
- 1987... sorta
How about swapping out a 3.0 for a 4.0? Is that a pretty straightforward swap?
I have a 3.0 Vulcan, rear wheel drive, auto tranny.
Unlike the 2.8/2.9/4/0 which are all "Cologne" engines produced
by Ford of Germany, the "Vulcan" engine doesn't share the bellhousing pattern, so to convert TO or FROM a 3.0 requires the transmission
to be swapped as well as the engine.
what interchangeability there is between the 2.8. 2.9 and the 4.0
is simply amazing... it goes under appreciated.
but what makes things really easy is when you discover that the Y-pipe from one will physically bolt to the others...
that they all have the same bolt pattern, that the engine is internally balanced and that allows the flywheel from the later engines to be used
on the older ones.
AD
