any 2.9L pics please!!!
dgndngrngr
Bessemer, Michigan
does anyone have a few pics of their 2.9L engine (especially the passenger side)? im trying to match up vacuum lines and other plugs that have no connectors. the bigger the better! thanks!
These are all I can find on my computer, if you need more pics, ask where on the engine you want a close up of an ill see what i can do :)
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
thanks to both of you ive been able to get all most of the connections figured out! there are still a few connections that im not sure of:
This one is a green vacuum line that is plugged with a screw, not sure where it goes.
and what is this? i cant find it in my haynes manual either. is it a temp sensor?
no problem man were all here to help any way we can :)
From a 1987 Bronco II, Auto/4x4.
CraigK
Off topic, this image from a photographic stand point is amazing, has a lot for the eye to see and the color tone is almost perfect for the subject. I love the lighting though you were probably not going for that, it is very good.
Nick
The green vacuum line goes under the red square i drew on this picture.
http://i527.photobucket.com/albums/cc351/gertsdsbs/spout001-1.jpg
Not trying to hijack the thread, but I see in this picture aluminum tape on the evaporator housing for the AC system. Mine has that on it also, I always thought a previous owner had added it as an add-on for some reason. Is yours original? Do you think it was put there to reflect the manifold heat away from the evaporator?:icon_confused:
Yep, it is insulation.
Nick
