- Feb 20, 2021
- 2.9 V6
- Automatic
The antenna mast is definitely not factory but the base look original but I'm not 100% sureIs that the factory antenna wire? Looks very odd for a ford.
Anywhoozle, try crutchfield.com. they have everything like that and you can look up the parts by vehicle.
What do you mean ?
*EDITED* welcome to the site.
No... He’s just a little strange. Don’t let it bother you, he means no harm and is helpful at least 75% of the time.I don't know what was that but it felt like a insult or a way to make fun of me.
Yes I went back and picked the antenna in the trash, the part with the pin was part of the antenna base I unscrewed the rusty antenna with a vice grip and a pair of pliers, ordered a new one on ebay.I don't believe that part was intended to come apart like that.
You'll need the whole metal bottom piece that mounts into the cowl (has the mounting flange on it). Should be very easy to to score a good one at a junkyard if you strike out elsewhere. Should be the same (or at least similar) on any '89-'11 ('83-'11?) Ranger, Bronco II, or '91-'01 Explorer (probably others too, though I recall F-series antennas have the flange at a slightly different angle).
