another timing problem
Black Ranger 4x4
3rd Gen
yesterday i broke the harmonic valve sprocket on my ranger, trying to take of the timing pulley, now i can't find it anywhere, is the junkyard my only option to find this part?
can i have this made on a cnc lathe and put back on my ranger or will i throw codes?
Harmonic valve sprocket?
Do you mean "harmonic balancer"? I have an extra one in my garage if you need one. Other then that you'll have to get one from the junkyard I think.
Allen
yes i did mean the harmonic balancer, i was able to finally find one at the ford dealership, it comes with the pulley as well in the kit. for a 116$ i would keep looking for another one, but i need to put my truck back together since this is my daily driver.
i did look at every junkyard in portland oregon, and no one had one, i think thats kinda weird, i almost bought another engine to take the part off of, but now i will just put on the dealer part, and put my turbo engine back for the future still.
i still can't get the crankshaft pulley off, ive tried bumping the starter, ive tried an air impact, ive tried heating it up. what else can i do to get it off?
this might sound silly, but if you are replacing the part anyway, try hitting it with a hammer and if that dont work, go to auto zone and rent a harmonic balancer puller. that will make life a lot easier after you take out frustrations with the hammer.
Are you talking about the bolt or the harmonic balancer itself?
If it's the bolt, then try a long pipe over the ratchet to get it off for leverage. The threads are normal (counter-clockwise to loosen) so you don't have to worry about reverse threading or anything.
If it's the actual harmonic balancer then do as said before and go get a puller if you don't have one mate!
Allen
yeah the bolt is what im having problems with, and i have tried the hammer thing, the leverage thing, big pipe over the wrench thing, and every other thing i can think of. how hot could i heat it up to maybe loosen it up, without hurting enything?
I just did this 2 weeks ago ! Used a belt wrench( as my timing belt had snapped ) and a
1/2" electric dewalt impact gun . 10-15 seconds with the gun & she came right out.
Use a breaker bar, put it on at the 4' O clock position, then put a floor jack under it and lift away. With a 1 foot bar the weight of truck will put 3000 FT LBS of torque on it, I don't think any impact gun will do that.
Just like this, this also works real good on drive shaft bolts or anything eles thats a bitch
that's a sweet way to do it man, but it still didn't break it loose, i can see the whole engine wanting to turn out of it's bolts. I'm about to just put my baby in front of my house and make my number 2 driver my number 1. then put a new engine in the ranger, i think it's time for a bigger engine anyway.
:thefinger::thefinger::thefinger::icon_cheers:
___________________
95 ranger 4x4 2.3 3in lift 33swampers home made back bumper homemade front bumper, pia lights, 5000lb winch, 12in sub, home made snorkel home made exhaust, home made dash, currently awaiting engine swap, thinking about putting in the turbo swap 2.3.
What I did on mine was use a socket and breaker bar set up so the bar was resting on the driver's side frame rail. Then I bumped the starter. But BE VERY CAREFUL!!! You could have the tools flying around the shop, recommended as a last ditch effort only!
yeah man i tried that as well, i had a huge breaker bar and a huge 7/8 in socket. i bumped the starter several times, and all it did was stop the engine without the bolt turning what so ever. :icon_confused:
