another dead 3.0
burn0ut
them hills in wv
not here for a long time, only a good time... AFFA
so on my way into the woods for a day of bowhunting yesterday my 99 4x4 MT, decides to start knocking squealing then stops dead on the trail, im fairly sure its toast, and even if its not i dont have time to try and fix it, however i do have 2 possible donor 4.0s in my back yard.
the one is a 92 4x4 ranger AT with 132k, the other is a 93 explr AT, and unless the odometer is wrong and judging by the shape of the engine im guessing its not it has 4,788 miles on it so this is probably going to be my donor,
now my question..
do i have to try and track down a MT for a 4.0? or will my 3.0 Tranny work the tranny code on the 93 explr is "T".
i left my keys in my buddies truck that rescued me so i have to wait until he gets here to get the tranny code off my 3.0 ranger.
but if anyone can shed some light as to if this is possible or if i need a tranny until then would be greatly appreciated.
ok so all hope of the 4.0's going in is zero, mod delete this thread if u want, ripoff artists at the local yard said 600$ for a 127k engine :( this day sucks more and more
change out the camshaft position sensor on your 3.0 and you should fix the problem and lose the squeal....hopefully your engine didnt hurt itself when the oil pump quit turning from the cam drive gear.....there is a lengthy post on here about the camshaft position sensor on 3.0's needing changing by 100k.
Good Luck......wagonmaster....
FYI. the 3.0 has a different bellhousing pattern than the 4.0
4.0s share patterns with other Cologene engines, the 2.8/2.9/4.0
the 3.0 is a vulcan engine, different animal
