- Dec 6, 2009
- maplevalley WA
- Automatic
Make sure the grounds are all good, You have battery voltage at the alternator large connection and the voltage regulator A terminal on your schematic above and they are the same. Field and stator wires go between the alternator and the regulator check for shorts if you have the choke hooked up to the stator wire disconnect it and then look for shorts. Key on ignition goes to the I connection. The tech library undercharging system troubleshootin will help you isolate the fault. GL
