- Aug 7, 2007
- Costa Mesa, CA
- State - Country
- CA - USA
- Other
- 2004 Bronco Badlands
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 1.5"
- Tire Size
- 33"
Recently my AC pump started cycling on and off when the engine in at idle in AC modes. I know the AC activates in many modes to keep the windows from fogging up. Initially when it kicks on the rpm drops so much that the engine feels like it is going to die. It doesn't seem to do it when driving at higher rpm or at least I don't notice it.
I replaced the AC clutch cycling switch several years ago when it would do this sometimes with the AC on. That solved the problem then. I know AC pump can cycle on and off at a slower frequency when the charge is low, but the AC is working fine.
Is there anything else I should consider before changing the AC clutch cycling switch?
