Ac cycling noise and recharge issue
The 94 or the 06? The 94 I can believe that. The 06 should hit about 43* and then you should see the temp jump about 5 degrees as the compressor kicks off.
Nope, it's the 06. I just did a full evacuate, replace accumulator, vacuum and recharge this week. :D
Yes, there is a schrader under the switch.
Thank you kindly for the info. I replaced the cut-off switch (hi-pressure) and gave the A/C system a quick top-off. This resolved my quick cycling of the compressor, allowed the A/C system to be fully charged, and gave me a 10*F more drop in temps (was 44*F, now 33.1*F). I'm back to freezing under the hot blazing sun. :yahoo:
I know, not the best proof picture. It says 33.1*F. The air coming out of the vents was so cold, the display was getting dimmer.
