abs valve fittings
Am4wag
Eastern Shore,Md.
I want to remove the abs valve and join the two lines together.I tried unions,however 3/16" is too small and 1/4" too big.So am I correct in assuming these are metric (?),and if so-what size?
need to know the same thing for the same reason
did you have any luck?
I did this to mine not long ago to my 91, I forget the size off head. Ill find out for you guys tomorrow.
I ended up cutting the lines and changing the fitting then reflaring the lines to 3/16
