Adsm, does the light have to be on constantly to pull codes for the ABS system?
Did I get you correct that an '07 hub is a replacement/fit for an '01?
Got a similar problem. Started as an intermittent grind on the left front. Thought is was a brake issue. Sounded like I had a piece of gravel in between the rotor and pad. Replaced the pads and rotors last summer. Went away for about three weeks. Then came back. I did notice the abs engaging once in a while at the end of a stop at the bottom of my driveway. Just thought it was gravel at the bottom of the driveway.
Now a slight turn to the left and at the end of the stop, ABS engages. No abs light as yet. Yesterday did so on a straight stop and pulled to the right. Dealer, a good friend, said they replace a lot of sensors. Now I am wondering based on this thread that maybe the hearing is going. Heck I can get a complete hub and sensor (Timkin) for $186. The sensor alonne is $135. But the work to replace the hub is, not fun.
Any thoughts or help?
Just ordered the hub!!! Real good price.![]()
