- Mar 18, 2013
- Automatic
Well As in my other thread, I finally got the little ranger running only to have it quit again today. The fuel pumps again are not running. The relay closes when you turn on the ignition but the pums do not run. The rear pump is brand new. The relay has 13.0 volts and when the relay clicks it passes 13.0 volts then a second or two later it clicks again and there is 5.0 volts on the line. Fuses are good, I'm running out of ideas. I'm leaning towards a bad ground or a shorted out pump.
