a4ld transmission problems.no O/D
s2pidyeah
Ewa Beach
went wheeling dis past sunday, everything got wet.in my truck under da hood i mean everything got wet. now my truck doesn't wanna shift into o/d. i can put da shifter lever in o/d but still no go into 4th.
1992 Ford Ranger 4.0L OHV A4LD with manual T-case
possible cause computer?
Similar issue with 1990 B-II
I have a 1990 B-II that the O/D stopped working in it a few weeks back, right immediately after I changed out the radiator. The symptoms are: when cold, the O/D works like it is supposed to, but when warmed up, it starts falling out of gear when you back off the throttle any, only going back into O/D when you step on it rather briskly. Eventually, it will no longer go into O/D at all. I can shift to D and it stays in gear no problem, just like it is supposed to, but if I shift back into O/D, even though it will not go into O/D, when I let off it, it falls out of gear totally, no matter what speed I am traveling.:icon_confused:
What I've done so far: Changed the fluid and filter, checked the computer for any codes (none), and changed the throttle position sensor. It also has a 180 degree thermostat, and an open element air cleaner mounted on the fender where the old air box used to be. Also, the radiator I installed came from a 1988 model B-II with the same drive train and the donor ran fine before I stripped the radiator and a few other (cosmetic) parts from it. The donor had been wrecked and totaled by the insurance company. It was hit in the front, (obviously not bad enough to damage the radiator), and all down one side like it slid on that side, perhaps in a ditch or something. I don't think it rolled because none of the windows were broken.
Did you get the computer wet? If so the computer could be the problem as the A4LD uses the computer to lock up O/D. You also need to check the connection on the drivers side of the transmission. Take it off and make sure it is free of dirt and grime. Check the wires that go to it also.
CTBob; Your problem sounds more like a Torque Convertor.
