Nailzs
- Aug 8, 2007
- Age
- 38
- Manual
several a4ld questions i have that i couldnt really find definitive answers to in the tech library
1. can you use the 4.0l specs and parts from a 90-94 a4ld to rebuild and strengthen a 86-90 a4ld?
2. is a 90-94 a4ld a simple plug and play swap(as in bolts right in, no wiring necessary, uses the same plugs, the ecm will not know the difference) for a 86-90 a4ld?
3. can you use a 87 a4ld for a 88 vehicle? im leaning toward no on this one as i read that in mid 88 a 3-4 shift solenoid was added
4. how do i tell if an 88 vehicle has the 3-4 shift solenoid?
thx guys
thx guys
